Valves are fine, Piston is fine. Belt obviously never jumped Tonnes of metal flakes in the bottom end.. and a few have left small scratches in the bore, not bad i cannot feel it with my fingernail im just going to use it as it.. As for why a compression test showed 0 psi on the whole bank, i have no clue, maybe my 2.2mm cometic gasket failed but held pressure below 100PSI for the leakdown test. Just hoping its the main bearings/rod bearings and not the actual rod bearings as they were brand new with the pistons and from what i understand not replaceable
